Bodyside molding
I need some help locating a part number for adding some bodyside door molding on my 04 2500HD reg cab/ utility body. The truck is the WT model in carbon metalic color. I found this @ the Sun chevy website, http://www.trademotion.com/partlocator/ind...004&catalogid=2 . Is this what I need? If so with what do I fasten it to the door with ?
One more thing, nerf bars, which set do you recommend? I do alot of driving in the mud/snow/sand so the black painted sets are out. I have seen them frame mounted, which i think may be stronger and ones that get mounted where the body bushings are. I dont want to spend over 350 for the pair, and like the idea of all stainless steel mounting hardware.
Thanks for the help.
KT.
I need some help locating a part number for adding some bodyside door molding on my 04 2500HD reg cab/ utility body. The truck is the WT model in carbon metalic color. I found this @ the Sun chevy website,[url=http://www.trademotion.com/shoppingcart/index.cfm?action=viewCart&siteid=213984&retval=index%2Ecfm6 . Is this what I need? If so with what do I fasten it to the door with ?
One more thing,  nerf bars, which set do you recommend? I do alot of driving in the mud/snow/sand so the black painted sets are out. I have seen them frame mounted, which i think may be stronger and ones that get mounted where the body bushings are. I dont want to spend over 300 for the pair, and like the idea of all stainless steel mounting hardware.
KT.
your link doesn't work.
Do you want a set like mine?
I replaced the stock ones with 02 GMC ones
link fixed.
Thats would work fine. I just need to try to keep the door dings to a minimum. :cheers:
I guess with the moulding ending @ the back of the cab it sould look fine, because of the reading utility body.
Where did you get them?
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,029 Guests (See full list)
