Linex question
I'm contemplating adding the following mod to my list of stuff I will be doing sometime in the future- getting the lower half of my truck (from the body crease down, all the way around) linexed, with the smoothest surface they can do.
My main question is whether I can put the body side moldings back on after it gets the treatment? I don't know if the molding tape (3M molding tape, right?) will stick to the linex well or not, but I think that the black moldings I have now w/the silver insert strip would look sharp on the black linex lower half. Pretty much a two-tone effect to my truck, and it would blend the fender flares and moldings into the look better than the current black on solid blue paint treatment I have right now.
I also have a sort of side question, how does the edge of the treatment look where the linex coating ends and unprotected paint begins? (Probably varies a bit between shops, but what's the best I could expect?)
Thanks for any replies on this guys, and I guess the answers I get will help determine how my truck ends up in the long run.
I don't think the 3M tape will stick to the Line-X surface. The surface is quite rough and there would be air voids that would not allow the tape to stick properly.
The edge of the Line-X is actually quite good. They tape down a very thin wire along the edge and then pull the wire up through the Line-X coating after application. The coating is about 1/16" thick.
Over time, the Line-X coating will fade with the sun, and turn gray. You will have to use a plastic trim dressing regularly to keep it looking good.
I'm not sure you would be happy with this finish. Line-X looks great inside the bed, but would look kind of crude as a surface finish for the exterior of the truck.
Also, if you changed your mind, there is almost no way to remove the Line-X finish once it is applied....
I have seen a few trucks with the Line-X sprayed on the lower portion like you mention... They look good! The trucks that I have seen all had the Line-X applied below the body molding tho... The way that the Line-X is applied, it is actually pretty smooth. They apply the rough texture at end of the installation process by kinda of "raining" the product on.
I think the 3M tape should adhere to the liner material pretty good if they don't apply the texture... Ask the Line-X dealer what they think about the tape adhering. You
The seam line where the product ends should be very clean. When I had mine installed over the rails, they used a tape that had a small wire embedded in it. When they were done, the wire was pealed away and the result was a perfect line...
Also, while the liner will fade a bit, mine has not turned grey. It is still a nice shiney black. That is with the truck parked out in the Texas sun year round... My liner was sprayed about 3/16 thick on the bottom of the bed and slightly less on the sides and over the rails...
Here is a pic showing the edge of the liner... If you get this done as you described, be sure to post a pic!
James.
Thanks for the feedback! Be sure that if (likely when :crackup:) I get it done I'll update the pictures in my Garage here. It probably won't be until late this year or early next year though. I'm just building my "to do" list, and right now I have my spring upgrades already budgeted out. (Full length stainless tube steps, Fold-a-Cover, replacement overhead console w/HomeLink, and replacement rear dome light w/two buttons).
I liked the idea of line-x on the lower half after reading that someone else had done this to their truck (couldn't locate the post though, so maybe it was on another site?), but I wanted the body side moldings on it for the nice extra "touch" that the chrome insert will add.
Anyway, I've added the treatment to my dream sheet. I even think the wait won't hurt much, since it'll also cover up any minor nicks or chips that the lower panels get in the meantime. :cheers:
I think the 3M tape will stick. The tailgate seal for the Fold-A-Cover is held on with 3M tape. There is no way that thing is going to come off my tailgate that has Line-X on it.
Great! Now I just need someone good with photoshop so I can get a better idea of the final appearance than the one in my head. :(
If you go to line-x.com and look at their photos there is an S-10 with the fender flares and the rocker panels done. Just about every day I see a Fullsize 95-98 obs, ext. cab short box that has line-x from the crease down, and he DOES have the trim on top of the line-x. So there's your answer and if it's going to fall off it would fall off up here (UP of Michigan), considering the nasty road conditions that we have.
Have a good one... :(
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
