Anyone recommend a type of rollpan?
I have a 2004 Silverado and I am now in a situation in which I HAVE to replace the bumper. Someone hit me. But instead of kicking out the cash for an exact replacement, I've been thinking about putting a rollpan on there. Does anyone have any recommendatons for what type or through what company?
Sir Michaels Steel was good for me. Hint of advice, don't smooth the gaps at each end, if it gets damaged again it will minimize the repair cost. Another thing to consider is if you have the NBS fullsize the factory hitch bolts to the bumper so it will need replaced as well. If that is the case take care to coordinate the new roll pan, hitch and spare tire clearances. So that the hitch sits right behind the license plate. (cool factor)
In my case my bumper is damaged as well and I like the look of a roll pan, but the cost of and painting the roll pan, installing, new hitch, etc... make a new bumper more practical to me.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
