98 vortec 5.7
Hi guys ! , I am new , and i just picked up a new ( new to me )  98 chevy 1500 , extcab, swb, stepside , 350 , auto , and 3.42 rear , with the G80 limited slip option,  I was wondering , what this thing should run in the quartermile or 0 to 60 ? , it all stock right now . thanks....98step
Welcome to the forums! I'm not sure about your question, but I hope someone can help you. Is your truck 2wd or 4x4?
Have fun and post often!
Later
Wlcome aboard 98.
In regards to your trucks performance,you are probably looking at anywhere from and upper 15-middle 16 second quarter mile time with a 0-60 time of around the 8-9 second range.
Those numbers are just my guesstimation with the 255/340(?) ratingd the Vortec 5.7 had from the factory and that's also assuming it's in very good runnig condition.
Thats about what I thought , low 16's  and 8 to 9 sec on the 0 to 60 ,  my old TBi 350  powered chevy 1500 extcab  was running about 9 flat 0 to 60 .
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
