Service Engine Soon?
Today I pulled up a PO161 code. It said it was an 02 sensor heater, bank 2 sensor 2. What does that all mean? Where do I find it if it needs to be fixed? Thanks!
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
