Fuel light problems
This has happend several times now and I was hoping someone would have an idea on a fix. Fuel light comes on and the neddle goes to empty, I can open and shut the door or restart and the light and needle go back to normal. Could it be a loose wire on the cluster or a meter?
2001 ecsb 4.3 with 60k
thanks,
tim
thanks,
tim
I had a similar problem with my 02 Burb. It ended up being the sending unit in the fuel tank. It also might be the connection to the sending unit.Hope this helps :rolleyes:
Welcome to yet another big common problem on our vehicles, thanks to GM useing very cheap parts and wanting our $$$. Do a search and you will see just how common this problem is. I have it with my 99 Silverado with 93,000 miles and have had it for the past 10,000 miles and am going to wait till its over 100,000 miles before I see how much it will cost to fix.
:withstupid: Join the club! I just use my trip meter and some where around 250 miles it's time for a fill-up, reset and just ignore the fuel gauge...Kinda puts the fun back into driving! :rolleyes:
Its been 4 days now and it has not happend again yet............. By the looks of the post I bet it will soon :thumbs:
  • 1 month later...
Its been 4 days now and it has not happend again yet............. By the looks of the post I bet it will soon  :tear:
My 2005 Suburban with less than 7K on the dial did the same thing as decribed above. I'm hoping it's a one time issue with this new SUV - I guess I'll wait for another failure until I take it in for warranty work.
The fuel light is just another of GM's little things to build comradely among its customers. :tear:
The fuel light is just another of GM's little things to build comradely among its customers.  :confused:
and another example of poor Quality Control and testing and why more and more people go with imports. Its the little things that make the biggest difference! :tear:
You can buy the sensor only from GMpartsdirect. The last post about this had a part number. Much cheaper than the entire assembly.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 1,253 Guests (See full list)
