Loud backfire blown muffler now wont run
I have a 95 GMC Suburban 120000 miles last night it hesitated twice then Backfired very loud and died. I looked under and saw the muffler blown open. It will start but when you apply gas it dies. under the hood there was a cable laying off that we reattached to the throtle arm? Still will start and idle but dies when you try to drive. Please help me narrow what it could be, I'm not much of a mechanic, but, can replace parts fairly well.
No, sorry, it is stranded at a friends house. It looked like a bike brake cable. It connected to a box against the firewall on the top of engine compartment drivers side.
Does that help?
I did reaatach it but it seems like it could come off again.
That is your cruise control cable.
I'd look for a cylinder not firing, bad coil or plug maybe. That will send the unburned gas/air charge into the exhaust, and the muffler is usually the weakest link when it blows!
Thanks for the reply, that makes sence on the cable. My cruise just stopped working the other day. Now maybe if I can get this other thing fixed it will work again as well. I will check the cylinders.
Check to see if you TP's are opening and the injecter's are in place, you could of had a back fire back thru the TB and bent the plates, Just my .02
Hope everything come out ok
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
