fuel pump replacement
my fuel pump has been giving me trouble lately. I know its the fuel pump because I've replaced the filter. I think it's going out because of my high miles and the previous owner NEVER ONCE changed the filter even after 70K+ miles.
Just wondering if anyone has been through it, how much it costs at the dealer and what not. I know the pump is actually inside of the tank, that's about it though. Did a fuel treatment bottle the other day. Anything I could do that I don't know about?
Thanks.
My brother and I changed mine out in about an hour. It was the first and only one I've done. If you have some help it's really not that bad. Some people will tell you to take the bed off and some will tell you to drop the tank. I chose to drop the tank. It had less than a quarter of a tank of gas. If you drop the tank, make sure the area around the pump is clean before you take it off. Good Luck.
Changing the filter has lots to do with pump failure. If the filter is plugged the pump has to work that much harder and at higher pressures to push the fuel through the plugged filter which leads to heat build up in the pump. it is said to be one of the leading causes in pump failure.....
Agreed. The more clogged the filter, the harder the pump has to work. Common failure is in the wiring harness in the tank. I change my filter every 10,000 miles just to be safe as a fuel pump replacement on my Tahoe was $600. My original lasted 70K and I've got that much on the second and it is much quieter than the original was before it failed.
Can you change the pump as a unit or do you have to change the whole module as I have read elsewhere. I have a 97 GMC. Thank you.
I had a 97 and had to replace the entire module. That was what the original was so there was no way to seperate it. Some years can be seperated and only the pump can be changed.
Also, make sure that you never go below a 1/4 of a tank of gas. The gas in the tank will help keep the pump cool. Dealer quoted me $330.00 for the pump on my '00 5.3, not including labor.
On my '97 Chevy, I changed just the pump and the strainer (little filter at bottom of pump).
Thanks for everyone's replies. I think I'm gonna go ahead and see if my buddy and I can't do it ourselves. Let yall know how it goes.
I did mine recently and found it eaiser to remove the bed to get to it. But of course, I had a full tank of gas when it stopped working. If you do a search for fuel pump in the forum, you will get several hits with suggestions and tips about replacment.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,164 Guests (See full list)
