Congrats to MightyHD
facn8me
GG Alex!
I had a tough time deciding, with Alex's truck being very nice and Facn8's truck being awesome but I had to go against the grain.
I was one of the few, the proud who threw my vote to the Syclone.
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 696 Guests (See full list)
