new shocks
hey guys. i just got back from glamis and my new shocks are awsome. i put on the bilstein off road shock for 4-6 inch lift developed by RCD way better than the rancho 9000 i had and look cool zinc plated! i got them from jackit.com #
bilbe5-6133-h5 2 @ $69.95 $139.90
bilbe5-6134-h5 2 @ $69.95 $139.90
i thought i'd post this because how hard it was for me to find bilsteins for my lifted 4x4
Tell me more. Did you just crank the stock torsion bars or do you have the Ford torsion bar keys as well? Is your truck a 1500? How was the ride before the new shocks compared to after? How much travel do you have bump and droop?
I have a 2000 Silverado and a 2001 Tahoe that I am needing some shocks for. I had pretty much given up on finding a replacement that was longer than stock but that wasn't too long.
Thanks!
B.J.
it has the rancho 4 lift, i cranked the stock torsion set up. as far as travel i dont know . it is a 1500. the rancho shocks would adjust stiff but the rebound stayed the same and the truck would bounce back hard. i think that these would be to long for a truck with out a lift. you could call bilstein they are the ones that told me about where to get them
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,032 Guests (See full list)
