Anybody know where I can find a diagram or instructions on how to take apart my dash to remove my stock radio?
It's for a 2004 Oldsmobile Bravada.
The stereo install kits usually come with some instructions. Sometimes they are pretty detailed and sometimes they aren't so much.
According to the service manual, it may not be terribly difficult. You need to remove the console shift lever bezel. You then remove 2 screws at the bottom of the center stack panel. You should be able to pull it away from the dash. There are several spring clips (7) holding the panel to the dash, just pull carefully but firmly, they'll release.
