PCM question
tmf6902
When GM comes out with an engine they are going to put into their cars and trucks, how do they determine the computer parameters that go with it (PCM settings)? Do they throw it on an engine dyno, and configure it for the best optimal mix of power and mpg? Do they do it mathematically, with the known specs of the engine, and then throw it on the dyno to really optimize it?
Also am I correct to assume, every 8.1L truck with an Allison transmission for example; comes with the same exact flash on it's PCM?
Gm starts off with dyno testing to get a baseline for the platform they will use the engine in. Then they will build real vehicles and test & doccument data. After that they will test production vehicles and make final calibrations. Then is off to the EPA for testing and certification. Production can then begin 2-3 years later. All engines in a family have different calibrations for different GVW,tire size & axle ratio and in some cases emissions for certain states.
Its a long process from start to finish.
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 463 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
