12V Outlets in Silverado
sincityZ71
GM-Tech or anyone else,
Okay. Slowly over the past month my outlets have been dying. Finally today I went to plug an adapter into the last working one left, heard a little buzzing sound for about 2 secs and it died. The other two died at some time, not really sure when. I have never really used them all that much, only when I took a couple of long trips, and then only to charge my phone when needed. So I am a bit disappointed. Any ideas on what may be the cause?? I am going to check the fuses, but since they seemed to die one at a time I am a little lost as to what caused it.
Thanks for your help.
The most likely cause is whatever you're plugging into them. The aux sockets are of a very simple (and durable) design and don't fail that I've ever seen. There are no moving parts, so I don't see them being at fault.
The only thing we ever see wrong is a blown fuse caused by a poorly designed adapter.
Well I will have to check all of that out tomorrow then. I tried 4 different adapters and none of them worked in any of the three outlets, so maybe there is a fuse problem. Just weird how they seemed to stop working one at a time.... :)
You sure it isn't your phone charger? Those things usually have a life span of 1.3 weeks....Could be shorting itself out...and killing your outlet in the process.
Just a thought.
Well they were all dead. The fuses where all blown for the three outlets, so I had to go under the hood and replace the cigar and aux outlet fuses. Did a test with my dads truck and determined that there is a problem with one of my adapters, when you plug it into and outlet, the fuse in the truck blows...haha...so I had to replace his fuses too... :) So now I need to see what is up with the one adapter...
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 826 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
