trailer brake wiring
duanew1
I have a 2005 2500 HD LS, and wired up the trailer hitch to pull my trailer. When connected the trailer brake control light comes on but it will only work when i manually move the control lever, and will only work in conjunction with depressing the brake pedal when the truck's headlights are on? weird? any help?
Did you use the factory harness?
Yes on the harness. I cut the factory plug end off and re-wired it to the 7 pin plug. Everything else works fine (lights, turn signals, brake lamps)
sounds to me like your using the wire for the back lighting from the harness to power the brake controller....
this would be why it works only with your headlights on... I would look into your harness from the controller to the under dash plug,
what controller do you have?
Yeah, weird, but I think there's actually a service bulletin on this issue, or something like it. I'll look when I get into work today.
This is the TSB I was thinking of, but it doesn't sound like it fits what you're talking about...
Trailer Brakes Applied When Headlights/Park Lamps Are On, Brake Controller Illumination (Modify Brake Controller Wiring Harness) #02-05-22-004C - (Apr 5, 2005)
1999-2005 Chevrolet Silverado
2000-2005 Chevrolet Suburban, Tahoe
2002-2005 Chevrolet Avalanche
1999-2005 GMC Sierra
2000-2005 GMC Yukon, Yukon XL
2003-2005 HUMMER H2
This bulletin is being revised to add additional model years. Please discard Corporate Bulletin Number 02-05-22-004B (Section 05 -- Brakes).
Condition
Some customers may comment that when the headlamps or park lamps are on, the brakes on the trailer are always applied, or that the back lighting for the trailer brake controller only illuminates when the brakes are applied.
Cause
The cause of this condition may be due to wiring changes within the vehicle electrical system for the 2003 model year.
Correction
Inspect the brake controller wiring harness jumper that is plugged into the vehicle relay block-body. The relay block-body is located under the left side of the instrument panel near the left kick panel, behind a plastic cover.
The 1999 though early 2003 wiring harness jumper that plugs into the relay block will have a reddish/brown 6-way connector and a tag with the last four digits of the wiring harness part number. Second design 2003-05 may have a white plastic connector with part number 5418 as well.
• The 1999 jumper is/was P/N 12171982 with a pink/purple tag identifier of 1982. This number has been superseded to 15366255, with a pink/purple tag identifier of 6255.
• The 2000 jumper harness is P/N 15366255. The pink/purple tag identifier is 6255.
• The 2001-2002 jumper is P/N 15086884. The orange tag identifier is 6884.
• The 2003-05 jumper is P/N 15085418. The orange tag identifier is 5418.
When transferring the brake controller with the wiring jumper attached from a 2001-2002 vehicle to a 2003-05 vehicle, a change to the jumper harness connector must be performed.
The following information is for the 1999-2002 wiring harnesses.
Pin
Wire Color
Circuit Number
Function
A
LT BLUE
1620
Stop lamps
B
RED
142
Brake controller 12 volt source
C
DK BLUE
47
Brake Controller output (Trailer Brakes)
D
BROWN
2409
Brake controller illumination
E
F
BLACK
1850
Ground
The following information is for the 2003-05 wiring harness.
Pin
Wire Color
Circuit Number
Function
A
BROWN
2409
B
RED
242
C
DK BLUE
47
D
LT BLUE
1620
Stop Lamps
E
F
BLACK
1850
Ground
To modify a 12171982, 15366255 or 15086884 harness for use in a 2003-05 vehicle, switch the wires in cavities "A" and "D".
To modify a 15085418 harness for use in a 1999-2002 vehicle (see model list at the front of this bulletin for applicable models), switch the wires in cavities "A" and "D".
Warranty Information
When the correct wiring harness P/N is matched to the specific model year of the vehicle, everything works properly. Therefore, conversion of an incorrect wiring jumper to match the vehicle would not be considered a warrantable repair.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Thanks! I will try switching the wires when i get home today, because I did take the controller out of my 2000 chev 1/2 ton and plug it straight in to this new truck, without changing anything. Sounds like that might just work......I'll let you know.
2003-2005 HUMMER H2
Condition
Cause
Correction
Pin
Wire Color
Circuit Number
Function
A
LT BLUE
1620
Stop lamps
B
RED
142
C
DK BLUE
47
D
BROWN
2409
E
F
BLACK
1850
Ground
Pin
Wire Color
Circuit Number
Function
A
BROWN
2409
B
RED
242
C
DK BLUE
47
D
LT BLUE
1620
Stop Lamps
E
F
BLACK
1850
Ground
  • 1 year later...
I have a 2007 3500 Classic that has the same problem. I am guessing the 05/06 wiring is the same on the 07 classic?
My situation is that I have a Brakesmart controller that worked fine for a couple of months but quit responding when I step on the brake. While waiting for warranty support on the Brakesmart I put in a Prodigy I have. I bought an 06 wire plug and connected it up but it does the same sort of thing. It doesn't do anything at all with the lights off (meaning it doesn't apply any brakes). With the lights on the brakes are constant.
Something I noticed with the brakesmart is that the third brake light does not come on when I step on the brake pedal but if I manually activate the brakesmart then all the tail lights come on. I don't know if the prodigy does the same since I cannot use it after dark.
The red wire on the brakesmart harness plug and the prodigy harness plug are in different spots. I moved it on the prodigy plug to match the brakesmart plug but then the prodigy doesn't work at all lights on or off.
I am wondering if I have 2 problems. One with the red wire being in the wrong spot in the prodigy plug and one with the truck.
Any ideas? Thanks
  • 9 months later...
Go to www.mygmlink.com and register. You can register without vin after you register they have a option to download manuals.
Then, find the section on fuses, most likely the trailer wiring fuse is either missing or blown.
Wow - lucky I happen to see this thread. I just picked up a 2001 Suburban and found a harness on Ebay. I thought they were all compatible. Turns out the harness I got was the 5418 from 03-05. So looks like I need to swap the brown and lt blue wires to make it compatible with my truck. Good to know!! I plan to install it soon as I need to tow the race car to a shop for some work in the next few weeks.
  • 6 months later...
I agree with the previous post... I am so glad I found this.
My Father in-law has the 2003 Silverado and the wiring harness for the 2002 model and his brake's symptoms were different, but dangerous:
The Light and the Stoplamps pins are reversed (per the earlier post). The person who installed the trailer brake module must have thought that the brake/lights pin was not connected and he kept the pin connector in place but also spliced the brake-switch wire to the same red wire.
Resulting symptoms:
- Drive with your lights on with the trailer and the brake is continuously engaged
- Drive without the trailer, but at night, and the brakelights of the truck are on all the time
- Drive without the trailer, during the day, all tail lights go on when braking
Do this long enough with the turn signal on during the day and a trailer and you will blow the fuse of the turn signal (I found that to be true for this truck at least)
I hope these symptoms help others who may run into this and don't make the link with the trailer brake.
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,133 Guests (See full list)
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
