Help! Radio Wiring question....?
I own a 1988 GMC 1500 Sierra with cassette and the little EQ thingy. I want to know the wire color and function for the radio & speakers. I am trying to install an aftermarket radio. Just need to know what color goes to what.
Thanks in advance.
Do yourself and the next guy down the road a favor and don't cut the original wires.
Get an adapter harness from Metra or another company.
Makes it a lot easier to install since you can make your connections on the bench instead of upside down in the truck with your arms in the dash up to your elbows.
  • 1 month later...
  • 5 years later...
I bought a wiring harness for it, but Im still lost lol. I've got the wires hanging from the back of the radio itself and the wires from the cassette player. Is the actual radio harness further in the dash?
Edit: Someone should explain that the main unit, also the main harness, is hidden underneath. Haha I just got my system up and running
WAT?
Well I have a 91 sierra. I took the radio head unit out (The controls) and then the cassette player out. I was left with 5 bare wires and then a harness piece that didnt match up to anything. Follow all these wires under the dash and you"ll find yourself another little unit underneath. Take that out and unhook it it. And bam...there's what you plug your store bought harness into lol
Blk=Ground
Brn=Park Lamp
Yel=Dimmer
Red=Ignition
Org=Mem
Wht=Data
These are the wires from the reciver to the control head.
Hope this helps :jester:
WAT?
I was just giving you crap for bumping a 5 year old thread. :jester:
Oh and for the speakers
Lt Grn=RF +
Dk Grn=RF -
Tan=LF +
Gry=LF -
Lt Blu=RR -
Dk Blu=RR +
Yel=LR -
Brn=LR +
Blk=Ground
Brn=Park Lamp
Yel=Dimmer
Red=Ignition
Org=Mem
Wht=Data
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 394 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
