Need Mirror advice
Hi all,
I need some help from the experts! I have a friend with a 2004 GMC truck with the electric folding mirrors, turn signals in the glass, heated etc. and he is going to trade in the truck for something that gets better mileage and he offered to let me swap the mirrors which I have on my 03 Yukon that are power and heated (no power fold or turn signals). The question is--is the wiring harness going to be the same so when I plug in the mirrors after the swap will the turn signals work in the mirrors? I am also not sure about the operation for the electric fold. I know he puts the L & R switch in the middle and pushes down on the large square mirror adusting switch (my switch pushes down also, but does nothing). Do I need to swap the switches too? Thanks for any help.
Gene
they should be a plug and play except you will need the dealer to program your door modules both drivers and passengers door modules for the power folding to work...
Also you should Not need to swap the switches!!! yours will work!
the signals and heat and power adjustments will work but will have to make a trip to the dealer for the power fold feature..
I have done this a few times now for myself and others.. the normal is about 10 minutes to program..
Should work fine otherwise!
Thanks so much! I kind of thought that would be the case, but I wanted to ask so thanks again.
Gene
  • 1 month later...
Okay everybody I just got the power, power fold, turn signal, auto dim and heated mirrors installed on my 03 Yukon which took less than 2 hours to complete. I just got back from the dealer who programmed them which intially said "hey you don't have power folding mirrors and you will also need a new door module!". After showing the tech that the mirrors had been manually folded and therefore they were not in their "detent" position he then said I still needed the module in the door and I said just do the programming with your Tech 2 tool and they will work and they finally agreed and said I would be charged anyway even if it did not work. Anyway 10 minutes later the job was done and they worked just fine, he apologized and said they learn something new everyday and had always in the past installed a new door module. Total cost was $40 labor. Note that you must start out with at least power mirrors for this to be true. :)
    Brendan C
    Brendan C
  • Who's Online   0 Members, 0 Anonymous, 937 Guests (See full list)
