anyone with a standard transmission and a cat-back exhaust get little backfires between shifts. If so anyone know why or how to fix it. I can live with it, but wanted to know if anyone else had a problem. It never did it with stock exhaust on it.
thanks,
Remy :cheers:
thanks,
Remy :cheers:
i have a corsa cat back kit honestly i belive your hearing the truck shifting from neutral to the next gear alot like you would have in a stick shift if you push the clutch in and then shift, that inbetween time would be neutral and cause the motor to rev high. i just installed the dynatech supermaxx headersystem on top of the corsa and now with high-flow cats, headers, and the corsa system this sound inbetween shifts is amplified. so unless you have a connection loss id say dont sweet it...
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
