Is it possible to Clear the corners
i CUT Open the headlights and took out the orange reflector and i like the look, wondering if this can be done with the turn signals the same way, and then just put in a orange light bulb or what?
Thanks
There are a bunch of clear turn signals on ebay and assorted truck accessory web sites - around 20.00
As for the headlight mod, what did you use to cut them open? I started to attempt this and felt like I was going to break something...I must of not cut enough or something
Just work at it with a good exacto blade or skinny very sharp knife, and a couple skinny flat screw drivers to pry it open. I broke a couple of blades doing it, but it just takes some patience. The silicon GM uses it crazy tough, but just start at the end with the reflector in and work your way around, you also have to pry up those little plastic clips. They work nice for resealing if you don't break them.
  • 4 weeks later...
    BigJake
    BigJake
  • Who's Online   0 Members, 0 Anonymous, 614 Guests (See full list)
