Avalanche 2500 Plastic
Does anyone know why the 2500 series Avalanche has the extra piece of gray plastic in the front wheel wells?
Hey Av3
Yes, my 2500 has the piece of trim that you mention.  I am assuming after looking at the 1500's vs 2500's that the front wheels sit slightly more outboard on the 2500.  This would leave the sheet metal more vulnerable to rocks etc. kicking up from the tire.  That is what I came up with after wondering the same thing.
Scott
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,025 Guests (See full list)
