exhaust rattle
Mattt
Ive got this annoying rattle from my exhaust. I crawled under the truck and can see where its coming from, but cant fix it. Middle of the truck near the cats, there is one pipe with a flanged connection, and another with a slip fit connection with a band clamp. Rattle is coming where the clamp is. No matter how tight I get it, rattle is still there. I had my local Chevy dealer take care of it a while back. It went away for a while, but came back. On the R/O they put, tightened midship exhaust(poor design).
Anything I can do to fix once and for all?
Thanks in advance.
Thanks in advance.
It is probably the o2 sensors. They are known to rattle.
Thanks for the info, but its not the O2 sensors. Ive been under the truck and can move the slip fit section of pipe with my hand. its definitely the pipe where it fits together.
I don't know of any specific rattles we have in the exhaust on those. Yeah, seen some o2's rattle, but it's a real light, tinny rattle. More like a ringing type sound.
Don't mean to hijack the thread, but I've been hearing what sounds like a small chain being dragged underneath. I guess kind of a ringing-chain link sound...not really loud though.
Wonder if this is o2 related?
Sorry again :thumbs: , Didn't mean to butt in :P
t
This is sort of a light tinny rattle, and its only when the engine is loaded. Going up a hill you notice it, Aso going in reverse from a stop.
The slip fit is where its coming from. The band clamp seems to be permanently fixed in position. Its as tight as it will go with a 1/2" drive ratchet and still loose enough to rattle. Any fix out there?
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 826 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
