Low Oil Light
My low oil light in the message center keeps coming on randomly on me. I am not low on oil and it is pretty fresh, only 800 miles since my last change. Could the sensor be going bad, or could there be some other reason for it coming on?
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
