Do I have remote start & amp hookups?
Okay guys, Here's a qustion for you:
I bought my truck a month ago and it had an aftermarket stereo installed, because there are wires that I don't know what they are for. It had a Delco casette/radio head unit made from 1996 in it, and since my truck is a 2000 I guess they put soemething cheap in it to sell it. (I have since installed a Pioneer head unit). Are the wires for an amplifier?
I also have a sticker on the engine shroud that says I have a DEI remote starter installed, and there is a switch and a light and a button installed under the dash.
There is a purple wire and it goes to the #1 ignition coil. I have tried various combinations of the remote start on my key fob and under the dash with no results. I'm pretty clueless on how remote starters work.
Anybody got any 2 cents worth of guesses/advice?
2000 Silverado, 4x4, 5.3l ext cab
PS How the %^&* can I add a picture to the posts?
You have to post your pics on a photo hosting site then provide the URL in your posts on this site and they will then show up.
Most IP's provide free photo hosting services or you can use sites like www.photobucket.com
Some of those are free as well.
The purple wire should be a tach wire. That is needed for a remote start to work. If it is a fairly new DEI remote start, you should be able to push the lock and unlock buttons at the same time to make the remote start work. try switching the toggle switch and repeat if it doesn't work the first time. As far as the extra wires for the radio... what color are they? if i knew that i could help you.
The only wire the stereo shoudl have for the amp is the remote turn on wire (blue). Then you will have your RCA outputs for the signal.
IF the stereo doesn't have that you will have to use a line output converter. I think even the cheapest Pioneer units now have at least 1 set of RCA outputs.
    JohnRoy
    JohnRoy
  • Who's Online   4 Members, 0 Anonymous, 671 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
