ABS AND BRAKE LIGHT ON HELP PLEASE
after install of new tires they are 37/13.5 /18 i recaled the pcm speedo is right on the money but now i have the abs and brake lights on is there anything i can do to the abs ecu
please help if you can
thanks
rick
Well in that case the problems not the tire size. ABS computers mainly compare speed differences between wheels and as long as the wheels all travel the same distance everything works regardless of the distance. Did you check the fluid level, really check it?
I just read your signature and see you've got some suspension mods. Check around each front wheel for damaged wireing and the single lead that plugs on top of the rear diff. If one of these wires got stretched out and broke or a tire rubbed it you'll loose that signal and loose ABS. Usually the ABS light would only come on. If both the ABS and BRAKE light are on you're either low on fluid or have a brake fluid hydraulics control problem in the ABS.
Did the lights come on right after the tire install or did it take a few days? And how long has it been on with you driving the truck? A lot of times if I run a vehicle on the lift with the drive wheels turning and the others still it will set an ABS code, but those usually clear once the vehicle reaches 45 MPH in normal condition.
Vernon
it happened as soon as i put the tires on i know the wires are ok
At this point there's nothing I could tell you to go look at. Have a shop read the ABS codes for you and go from there. I can explain them if needed to double check the shop if necessary.
Vernon
Rick at this point I don't think there's anything I can tell you to go look at and get it fixed. Find a place that can read the ABS codes for you and go from there. I can go over the codes with you if necessary.
Vernon
  • 3 weeks later...
Had a similar problem. Went from 3.42/235's to 4.10/265's. Within 1.5 miles the lights would come on every time. Hypertech used to re-program for tires & gears. Turns out that the ABS is programmed for wheel speeds also, using inputs from tranny output, as well as both front rotors. If speedo is cal'd for new gears/tires, it can be far enough away from the ABS calibration (certian combinations) to make the ABS unit think the front & rear wheels were constantly spinning at different speeds. This throws the lights and disables the ABS system. Hypertech said that their handheld (and I assume others) cannot program the ABS, so the only solution was to keep reducing what you enter for tire diameter until it goes away. I ended up with a speedo error of about 3%.
A lot of people never see this, as they are going with very big tires, and Hypertech only allows programming up to 34". Therefore, they are programming low anyway.
I have also been told that a PCM swap/tune can also correct the ABS programming...something the handhelds apparently cannot.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
