Has anyone tried modifying (successfully or unsuccessfully) the center console insert that houses the 2 "storage trays" and a cigarate lighter in a 2004 Silverado? Not sure what other years would be similar. I want to mount a Bearcat Uniden 780XLT scanner in there, but since this scanner is a larger one, I will have to cut quite a bit off the back. Was wondering if anyone else has tried this. If so, would you mind posting some pictures. Thanks.
I've cut out the lower tray to install a 6 disc CD changer and I know others have too, some have mounted DVD players in there and some have installed aftermarket stereos and CB's in there.
That looks pretty sweet! Thanks for the post. The trouble I am running into, is that the scanner I want to put in has enough space width wise, but as far as height is concerned, I think I have to shave some off the top, as well as cut off the hole back part out so the depth of the scanner can fit all the way in. Just wondering if anyone else has tried this. I checked the price of a new console insert at 60 some bucks for a stupid piece of plastic, so I would rather not destroy it if I don't have to :seeya:
I put my XM Commander in that little pockey but had it removed to trade the vehicle in and never got pics of it. Sorry man, but it can be done.
I appreciate the replies. I figured it could be done. Just wanted to see what others have done before I cringe and fire up the dremel tool and start cutting away.
Guest chevydeerhunter
Dude....why don't you clean up a bit before you post a pic of your truck?? :D
:jester:
hey BB, how hard was it to get the factory navi to work?  is your the touch screen
You guys got any info on that NAV unit? I'm pretty new to this stuff, I'm assuming its some kind of GPS system? Expensive? Sorry for the dumb question but hey we all gotta start somewhere right? :chevy:
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
