Orlando Transmission Shop
Hey Folks,
My '97 C1500 tranny recently started to exhibit the common 4l60 reaction shell failure:
Late shifting of 1->3rd at around 3500 rpm
No reverse gear
I'd like to drop the tranny and fix this $50 part myself, but I'm not sure I'm up for the task.
Can any of you guys in the Orlando area recommend any reputable tranny shops for this repair (I really don't want to buy a rebuilt or used?)
Thanks for the help
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
