2000 Yukon Service Engine Soon Light
This is my first time here, so forgive me if I do something wrong.
The Service Engine Soon Light on our 2000 Yukon is on. 68000 miles.
I've noticed that there is a Recall on the fuel pump and that is mentioned as a symptom. We have not received a recall letter.
Other vehicles we have owned have also done this just after 60000 miles.
Is this just the normal emission control warning light, do you think?
In the past, on our Fords, we would just take them in and they would do something to shut the light off. No charge as I recall, it was just so they could check and make sure the emissions system was operating properly.
How can we be assured the dealer will not rip us off?
TIA.
I would take it down to the local AutoZone or Oreally's. They'll hook it up and tell you what the code is for free. Most of the time, they'll be able to tell you if it's serious enough to warrant a trip to the dealer, or if you just need to tighten your gas cap :rolleyes:
Welcome to the forums by the way. :banghead:
Got another idea?
O'Reilly's wanted $210 deposit for the diagnostic tool.
Then, they would not do, connect it wherever it needs to be connected to take the reading.
If I did that, they would not tell me what the code means.
If I knew where to connect it and how to read it, then I would be a mechanic, probably, and have one of my own, and not need to use theirs.
:banghead:
Got another idea?
:banghead:
Go to Auto Zone. They will read it for you especially if you tell them O`Reilly wouldn`t. They want to sell you something real bad.
  • 3 weeks later...
Got another idea?
:seeya:
Advance Auto will also do a free scan. Do you have one of those close?
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
