Looking at a 98 S10...what to look for?
I currently am driving a 1989 S10. It's a 2.5L 4 cyl with 190000 miles on it. No air, no heat, bad windows, and just flat out old. I'm lookin to get a 1998 S10 since I've had such good luck with this one.
I did test drive one the other day and it had 100,000 miles on it but sounded like it ran really good. It had some extras on the outside like blinkers in the side mirrors, blacked out windows, roll pan, rims, euros, etc. But I'm more concerned with how it runs and if its mechanically sound. The transmission shifted great, air was cold as hell, it just sounded solid. They wanted $5300. I figure they'd take $5000.
Whats the deal with the 98 S10 4.3L engine? Tranny? Things to look out for once I reach certain mileages? I havent had any experience with this model or engine. My 91 Caprice tranny went out @ 165k and it cost $1100 to rebuild. I dont want that to happen this time around.
The engines are pretty solid. The thing to check are the oil lines. These tend to leak over time and are located down by the filter, also check the radiator for sludge, and the dexcool. In fact I would see if you could get the dealer to throw in a Dexcool coolant flush.
If you buy it, then change the fuel filter, oil, etc..
'98 has the new grille and interior, but the old (crappy) elephant ear mirrors and the old (1st gen) airbag.
4.3 is a really good engine, not the quickest but VERY torquey and moves on the highway nice, and at low RPMs. Decent fuel economy too. They never sound pretty.. it's an old school engine and is kind of "rough around the edges" but definitely a workhorse.
The oil line problem is only on the 4x4 models where the oil filter is remotely mounted. Fuel injectors/intake gaskets have been a problem I hear, and the front suspension (ball joints, control arm bushings?)
Overall I love mine.. I've got an 03 with 35k miles and it's been great so far.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
