Engine Vibration through gas pedal
imaniguana
I have an 05 Silverado Reg cab, V6, 5M. I bought it new in March. Brought it to a dealer in May for an oil change and state inspection. Got it back with vibration coming through the gas pedal. There was no problem with it, until I brought it in for the inspection and oil change. Took it back to the dealer 4 times to fix. Note: Before this, the engine ran so smooth, I barely knew it was running. Now, it has a high frequency vibration to it that is translated to the gas pedal and floor pan. (My left foot just sitting on the floor pan will even get tingling and numb after a while.)
First they applied a TSB for exhaust system vibration, even though it did not seem to be exhaust related. That didn't work. The vibration is still there and they're at a loss on how to address it further. They say the vehicle is "operating as designed" and the vibration is a characteristic of the 4.3 V6. (Not mine originally anyway.). I do not know of any vehicle designed to make your foot go numb. They sent me to GM Customer Service which tells me they have no fix for it. They told me to try another dealer.
I recently took it to another dealer, who's Service Manager, on a test drive with me, also noticed the vibration. After leaving it to be diagnosed, they reported they do not detect any vibration and they checked underneath for anything out of the ordinary. I have another appointment (number 2 with this dealer and number 6 total) with them to look at it again.
The bottom line is that I can't drive the truck much more without further and permanent damage to nerves in my foot. The tingling and numbness lasts for days after driving it.
If it were a minor thing, I would just ignore it and put up with it. But I put on a lot of highway miles and the vibration makes my foot numb and it continuously tingles. I've had the truck for about 4 months now and put 12,000 miles on it.
Any ideas on what happened to the engine to cause this vibration and how can I help the dealer to fix it?
I'm not trying to be a wiseguy, but if you have tingling and numbness in your foot that lasts for days from a vibration that they can't even detect, I think you need to see a doctor for a foot problem, not a technician for a truck problem.
To be clear, it's a high frequency vibration that some people can readily detect and others can't. The difficulty is that for some, they would need to drive it a while, as they might not feel it right away, but they sure would notice the effect after a while.
The foot numbness only happens with THIS vehicle and it started only AFTER the first service appointment. The vehicle was perfect before that. No engine, gas pedal, or floor pan vibration. Passengers even feel the vibration on the floor pan. I felt it myself when I had the Service Manager drive it and I sat in the passenger seat.
I should also add that highway mileage went down from 20-22 to 17.8-19.5 after first encountering the problem and has stayed within that lower range ever since. I fuel up roughly twice a week and the latter numbers are consistent.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,214 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
