Center cap inserts
I'm not sure of all the years they were available, but does anyone have the factory center caps for the rally wheels from a '91 Chevy 2wd 1500 Sport, or the 454SS?  If so, could you measure the diameter of the insert in the center cap?  Just the part with the bowtie emblem is all I need a measurement for.
Thanks.
(Edited by MountaineerTom 99Z71 at 9:34 pm on June 20, 2001)
Quote: from Shaners on 6:57 am on June 21, 2001
uhoh....  Tom's up to something again!!!  LOL
LOL
Actually, It doesn't have to be only a sport or 454SS, a regular Silverado will work.  They have a black insert with gold bowtie, where the other two have black with a red bowtie.  I'm curious if they will be the same diameter (3 1/8 inch) as the center part of my wheels with the gold bowtie and the words "chevrolet trucks" written around the edge.  If I remember right, the inserts are held on by double sided tape, like all the emblems.  If they are the same size, I may have to test fit a black/red one on my truck to see how it looks.
Just an idea I've been playing with.
This is the style I'm looking for, the inserts are the same size, just different colors.
(Edited by MountaineerTom 99Z71 at 9:02 am on June 21, 2001)
The wheel covers on that truck look exactly like the new ones I bought for my Suburban.  Do they bolt on from behind the wheel, bolt on from the front, or snap on?
FYI, the wheel covers on my Suburban are from an '88 model Suburban, bolt on from behind, and have 2-1/2" centers that are dark blue/black with yellow bowties.
I'll probably have a picture to post soon.
Hope this helps!
Jeff
Jeff,
That was my old truck.  It was totaled in a wreck in '99.  There's more pics of it and the mods I did to it on my page in my signature.  The center caps were held on by those black cap that thread on to the actual lug nuts underneath, very similar to the new body style trucks.
(Edited by MountaineerTom 99Z71 at 12:03 am on June 23, 2001)
OK, then they are different from my new caps.  I see now what you mean, before I couldn't remember any difference, but they are actually quite different.
oh well....
Jeff
I took a pic of one of my "new" center caps...the set is off an '87 Suburban, and is different from what you were looking for.  They were designed to screw into the steel wheel with self-tapping sheet metal screws, but they were plated steel and rusted pretty quickly.  I used stainless steel bolts from the back of the wheel with stainless steel acorn nuts on the front, like little mini lug nuts.  I think it turned out pretty well...
Jeff
(Edited by 76BBSub at 10:03 pm on June 25, 2001)
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
