3500 dually brakes throb real bad!
Are the rotors covered under the 3/36 GM warranty?
I just put new front Friction Performance Carbon Matallic pads up front to see if it would help at 30K miles. I have a feeling it may actually be the rear rotors?
I now have 32K and I am thinking of what needs to get taken care of before the 3/36 runs out.
Thanks in advance for any advise, Andy
they should be, it could be a problem with the hydroboost pump, it wont hurt to call ask
I called the local Chevy Dealer and he said the rotors are covered by 3/36 warranty and will either be cut or replaced if needed!
Thanks, Andy
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
