Occasional starting problems
mlacy
I have a 2000 Silverado and occasionally (about once every 2 or 3 months) it won't start. It usually happens if I'm in a hurry and let off the ignition before it fires up. Once this happens, it won't even try to fire. After about 10 - 15 minutes of sitting there, it will start fine. Is there some sort of security feature that might cause this? My security light comes on occasionally also - are they related?
Thanks,
Mike
  • 1 year later...
I have this EXACT same problem and found your post searching for a lead to solving my problem. (2000 GMC Z71 Sierra)
My security light comes on once in a while when driving too.
On top of that, it has also developed a serious hesitation off the line. Once cruising all seems well.
I have cleaned the throttle body and MAS, new PCV valve, fuel filter, fuel pump assembly ~ 40k miles ago. Used a hand held code scanner but nothing came up.
I am going to take it to the dealer to see if they can pull a code or something. Maybe my hesitation problem is related.
Thanks,
Mike
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 920 Guests (See full list)
