Keyless Remote
Here ya go,No tools or dealer required!!
1.Close all the doors
2.Insert the ignition key into the ignition lock cylinder
3.Press and hold the door UNLOCK switch
4.While holding the door lock switch in the UNLOCK postion,cycle the ignition ON,OFF,ON,OFF.
5.Release the door unlock switch,The doors will lock and unlock to confirm the program mode.
6.Press and hold the LOCK button and the UNLOCK button simultaneosly on one transmitter. After a delay of approximately 15 seconds,the doors will lock and unlock to confirm the programming of that transmitter.
7.Repeat the previous step to program up to four transmitters.
8.Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
9.Operate the transmitter functions in order to verify correct system operation.
I should have mentioned also that you must reprogram your original transmitter at the same time you program your new one (I.E. repeat step #6 with your original transmitter)
Since you all are discussing remotes, is there anyway to turn off the panic button feature? I am always accidently pressing it and it is a real annoyance.
I defeated this by opening up the remote and putting a strip of Scotch tape over the area where the panic button is. Problem solved. :shakehead:
    Brendan C
    Brendan C
  • Who's Online   0 Members, 0 Anonymous, 1,120 Guests (See full list)
