Owned Pictures, Flashes...
Scyry
I know there are tons of funny "owned" pictures out there, thought maybe a thread of them would be approriate, here is one:
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
