4.3L runs like crap.....Help
I just aquired a 93 GMC sierra pickup wih the 4.3L V6. I know this engine has about 30k miles on it as the previous owner had a crate motor put in a year or so ago.
But is now running terribly, There is at least one cylinder that is not firing....but I can feel it hit every now and then. The idle is rough and the acceleration is poor. I even backfires every now and then while accelerating.
I have done the basic tune up...plugs, wires, cap and rotor.....and that did not affect it at all....
I don't want to chase this with parts...but I don'e have access to much diagnostic equipment.
What could it be? I did a compression test and all cylinders were OK.
Dist module?
Fuel filter or pressure?
Bad injector...
Where should I start?
Thanks.
  • 1 year later...
Unhook the tan wire at the buss bar above the heater and set timing according to the sticker on the rad support or shroud. Probably around zero degrees.
    JustusTX
    JustusTX
  • Who's Online   5 Members, 0 Anonymous, 661 Guests (See full list)
