2" shackles
I am going to put 2" shackles on my truck sometime to level it out. Im wondering if my truck will sag in the back, be lower then the front when I have my quad in the back?
Thanks
A description of the truck might help a bit in answering your question.
What kind of quad would help as well.
4 wheel drive, 2 wheel drive? 1/2 ton, 3/4 ton? Reg cab, ex-cab?
If you have a regular cab short bed 2 wheel drive, and you drop the back 2", then drop a big 'ol honking Brute Force back there, yeah, it's going to sag a little.
My buddy has pretty much that truck (with the drop shackles) and his truck sits dead level with a 400EX back there.
Sorry. Yea thats what i got is a 2000 2wd 1500, reg. cab, and short box. And a brute force 750
Dang I'm a good guesser :banghead:
It will squat a little, but nothing severe. If you can find a set of Lord Corp. Velvet Ride shackles on Ebay or something, that would probably be the best way to go. They'll drop the back about 1.5 inches, and give you a better ride.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
