A little help please.
BigEasy
Hey guys, gotta question I tried several searches and came up with nothing.
2005 GMC Seirra Z71. 19k on the odometer.
This truck is on its way back to the dealer for the second time for this. :dupe:
The problem.
After the truck warms up to operating temp( I don't know if this has anthing to do with it but, it's just when I notice it. after driving about 10 minutes)
When I go to accelerate, say, merging into traffic on the interstate and I have to accelerate fairly quick. Not a "pedal to the metal" move but, just a good quick acceleration (say from 40 to 70 mph) my headlights, dash lights and interior dome/map lights if I turn them on "Pulsate" to the point that it is very noticable and people have even moved to the shoulder of the road like I'm trying to get them to pull over. It does it on low and high beams and almost exclusively when accelerating. Sometimes i'll notice it at a steady speed.
First time at the dealership the service writer told me that the Battery and Alternator checked out fine and that it was normal I said "No way you'll convince me that is normal" She prceeds to tell me that there is a TSB stating such and that she would fax me a copy (which I have not seen, by the way, even after repeated calls)
is there anything that any of you guys think may be the culprit? On top of being anoying, it's dangerous. there is no telling what on coming traffic thinks as they meet me. It aint funny but I almost gotta laugh :mad:
Sure doesn't sound normal to me. And I'm not aware of any TSB that says any such thing.
These things use a battery/generator control module nowadays. The generator is turned off when it's not needed, such as when crusing down the highway. You'll find this module clamped around your negative battery cable.
It could be that the generator is being turned on and off rapidly, which would not be normal. That's just a wild guess, mind you.
Good deal GM.
I'll politely suggest that they check the GCM when they call today. Really what needs to happen is they need to keep it overnight and let one of the tech's drive it home and drive it around tonight. Whether they will do that or not is another story :dupe:
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,236 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
