Headlights and Tires on '04 Suburban
I have tinkered with the headlight adjustment on my Suburban several times and the dims seem to only throw light about 15 yards at best. The brights are perfect, almost too good! I have raised them, lowered them, about ready to shine them in my face to hopefully improve results! :D:crackup:
The brightness is fine, they just don't throw light very far. My 2000 Silverado dim lights throw light almost twice as far.
I guess I am just lost. Any suggestions? I think I would like the Zenarc system, but don't want to spend $600+ for that kind of an upgrade.
I seriously have reservations about driving over 50 mph on a clear night because of the very short distance of light they provide. Rainy nights are downright scary.
Anyone?? :D
Also, do the Goodyear tires get noisier with miles or is it just me? I have put 12k on the Suburban since I bought it and they seem to be getting louder with age. Am I nuts?
I have tinkered with the headlight adjustment on my Suburban several times and the dims seem to only throw light about 15 yards at best. The brights are perfect, almost too good! I have raised them, lowered them, about ready to shine them in my face to hopefully improve results!  :D  :crackup:
Anyone??  :D
Hey there –
Unfortunately, no matter what bulb you decide to run on your Sub, you will still get only a marginal improvement. I originally ran the Silverstars in my ’04 to try and fix the problem – they looked cool but I still felt things could be improved upon. I finally made the jump to HID’s and liked them so much that I bought another set for my ’05. Nothing, NOTHING comes close to these headlights. The clarity, brightness, and distance these things produce made the $419 (per set) one of the best mods I could buy. I know $420 is a big amount $ to spend on headlights, but the additional safety and performance these things offer should make it something to consider – especially if you travel a lot at night on dark roads.
Regarding the Goodyears, I kept them on my 04 and they do seem to get louder as the miles add on. The tread life seems to be holding up pretty good, though.
Can't be much help on the headlight as I think the lights on my 03 are great but I have the t-bars raised some so that may help.
As far as tire noise. I had an explorer a few years ago and had ongoing tire noise issues. Mine was a wear issue on the front end. If I rotated the tires the noise would go away and then come back as the front tires started to cup. You might want to try rotating and/or checking the alignment. On mine it was hard to see the irregular wear but if I rotated them it would quiet down for 1-2k miles. Just an idea.
Thanks for the replies. Machine, what brand of HID lights do you have? Is the install pretty simple? A web page maybe?
Thanks!
Here you go:
Xenon X2020 HID’s from Sylvania. They are a totally enclosed, plug and play HID unit. You literally unplug and remove your existing headlamp unit and replace it with the new one. The ballasts and HID bulbs are all part of the replacement. It takes less than 30 minutes to replace and properly aim them.
I bought my sets from: Here
$414.00 per set.
My Mercedes has factory HID and the units I installed in my Sub's are as bright and effective as those.
    whenindoubtuseahammer
  • Who's Online   2 Members, 0 Anonymous, 353 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
