TIRES....
I know on the 4x4's you can stick some LT285's on them w/o any rubbing.  On the 2wd trucks I don't know if you'd have the clearance up front.  To be on the safe side I'd say LT265's, but I'm sure someone w/ a 2wd will give you a definite answer.
Welcome to the forum.
BTW, is that Harpo, as in the Marx Brothers?
WHAT ARE THE BIGGEST TIRES THAT I COULD FIT ON MY 2001 SILVERADO 1500 2WD?  ANY SUGGESTIONS WOULD HELP..THANKS
Had my 265/75/16 BFG AT's on my 2000 1500 2WD
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
