Resetting PCM
Is it necessary to reset the PCM when a mod is added, like intake and/or exhaust?
How is this done?
I have added Catback, intake and Hypertek, do i need to restore stock program before resetting?
Thanks.
How is this done?
Thanks.
It will learn and adjust on it's own. But the PCM will adjust quicker to the mods if you disconnect the positive from the battery, then touch it to the neg to instantly clear the short term PCM memory. Reconnect the positive and off you go!
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
