What rear end gear do I have
05Quadrasteer
How can I find out what rear end gear my truck is running? Do I need to get with a dealer and have them look up the original paperwork on my truck. I have miss placed the window sticker. Is there a sticker on the truck somewhere that will tell me what the gearing is.
Thank you and have a nice day.
Bill
Look on the SPID label (option codes) in your glove box. The codes that start with "G" will tell you. G80 is limited slip and ratio could be GU6, etc. If you get those codes, we can tell ya the axle you have.
All Quadrasteers have G86 posi units. Normal rearends may have G80 posi units.
QS rears all came with either 3.73 or 4.10 gears. 3.73s will be GT4, 4.10s are GT5.
Like Tech said, look on the glovebox door.
Hey Tech, off-hand, do you exactly what posi unit the QS have ??
I was told they have Detroit TrueTracs in them by a pretty good source, but we've been having a lot of rearend discussions lately, and a lot of guys have added posi additive to theirs, there's talk of them moaning and chattering, all things that helical posis DON'T do or need :chevy:
I'm not sure that they don't have truetracs, but I'm really beginning to wonder :crazy:
Thanks.
When you say "posi" are you referring to full time traction with both wheels. I really hate to be so dumb at times when it comes to all this technology stuff. Wanting to make sure I have all my facts and figures right as I am considering getting a tune done on the truck.
Have a nice day.
Bill
Actually, I don't. I've seen exactly ONE quadrasteer truck in here since they came out with it and it wasn't for a quadrasteer or axle concern. I looked in our service information, but it doesn't go into that detail.
Bill, actually when I say posi, it's really more of a limited slip than a locker. Is that more clear ?? Posi, if I'm not mistaken, is just a *brand* name for limited slip, like xerox or q-tip. You know the difference between a locker and a l/s ?? Regardless, it shouldn't matter for a tune.
Tech, I was at the dealer for something a couple weeks ago and asked the parts guy to look up the QS unit for parts and see what it had listed for the posi unit. Funny- it showed a regular rearend with the Q/S parts just kinda floating in space, and with an open diff !!!
Gotta love that GM attention to detail :chevy:
Well, if you ever can figure it out, I sure would like to know !!! Thanks.
I do believe I understand a slip differential. That is where the power is switched between tires if one starts to spin. Have heard the term locker but have no clue as to what it is.
Thanks for any information you can supply.
Bill
A locker is like a spool in a straight line- both wheels are LOCKED solid together with NO slip. When you turn, one will disengage to turn at a different rate. Lockers are known to have *bad* street manners, in that they may be jerky, loud, noticeable or all of the above. There are soft-lockers available these days, but even those are noticeable to those that have never driven a real locker.
A spool does away with the diff all together and locks both axles all the time. Most folks agree they are not for street use, although many people do use them on the street.
Found this on another forum:
RPO Code List
Description
The production/process codes provide the description of the Regular Production Options (RPOs). The RPO list is printed on the Service Parts Identification Label.
RPO
AC6  Window Tinted Deep, Rear, S/D
AE7  Seat FRT Split, Driver, PASS
AG1  Adjuster FRT ST Power, Multi-Directional, Driver
AG2  Adjuster PASS ST Power, Multi-Directional
AJ1  Windows Deep Tint, All Except W/S And DRS
AJ7  Restraint System Seat, Inflatable, Driver and Passenger, Front and Side
AL0  Sensor Indicator Inflatable Restraint, Front Passenger/Child Presence Detector
AL4  Seat RR BKT
ANJ  Window Tinted Export Compliant, Non-Deep
AN3  Seat FRT, Individual (Non BKT)
AP9  Net Convenience
ARL  Plant Code Arlington, TX USA
AS3  Seat RR
AT5  Seat Rear CTR, Folding
AU0  Remote Function Actuation - Keyless Entry - Domestic
AU3  Lock Control Side Door, Electric
AU8  Remote Function Actuation, Specific Frequency
AX4  Restraint Conversion Seat, Manual, European
A04  Windshield Tinted, Less Upper Shadeband
A31  Window Power Operated, All Doors
A95  Seat FRT BKT, High Back, Driver and PASS RECL
BAG  Parts Package Export
BG9  Rubber Floor Covering
BPH  Appearance Package Chevrolet Off Road
BS1  Insulation Acoustical PKG
BVE  Side Steps Runningboard
BVF  Side Steps Runningboard, Color Keyed
BVQ  Side Steps Runningboard, Tubular Chrome
BVR  Side Steps Runningboard, Tubular Stainless Steel
BVS  Side Steps Runningboard, Color
BW1  Ornamentation Exterior Rear End
BW2  Molding B/S Deluxe
BX2  Molding B/S Lower, Extra Wide
B30  Floor Covering Carpet
B37  Covering Floor Mat, Front and Rear, Auxiliary
B39  Covering Floor Carpet, Load Floor
B41  Covering Floor Mat, Load Floor
B58  Covering Floor MAT, FRT And RR, Carpeted Insert
B71  Wheel Opening Flares
B85  Molding - Body Side , Exterior, Bright
B96  Molding Wheel Opening
CF5  Roof Sun Glass, Sliding, Electric
CJ2  HVAC System Air Conditioner Front, Auto Temperature Control, Auxiliary Temperature Control
CJ3  HVAC System Air Conditioner Front, Manual Temperature Control, Auxiliary Temperature Control
C25  Wiper System, Rear Window, Intermittent
C36  Heater Auxiliary
C49  Defogger RR Window, Electric
C5H  GVW Rating 6,900 LBS
C5U  GVW Rating 6,800 LBS
C5W  GVW Rating 7,000 LBS
C5Z  GVW Rating 7,200 LBS
C6P  GVW Rating 8,600 LBS/3,900 KG
C69  HVAC System Rear Air Conditioner
C7K  GVW Rating 6,500 lbs
DF5  Mirror, I/S R/V LT Sensitive, Compass, O/S Temp Display
DH6  Mirror, I/S Front Van, LH And RH, Illumination with Sunshade
DK7  Console Roof Interior, Custom
DK8  Console Roof Interior, Deluxe
DL3  Mirror, O/S LH and RH, Remote Control, Electric, Heated, Power Folding, Turn Signal Indicator, Light Sensitive, Color
DL8  Mirror, O/S LH And RH, Remote Control, Electric, Heated
DNR  Equipment, Dealer Installed
DPF  Mirror, O/S LH and RH, Wide Load, Remote Control, Electric, Heated
DR4  Mirror, O/S LH and RH, Remote Control, Electric, Heated, Light Sensitive, Power Folding, Color
DT3  Rear Box Compartment, Stowage
DT4  Ashtray, Cigarette Lighter
DUF  Equipment, Duffle Bag and Daypack
D07  Console Front Compartment, Floor, Custom
D31  Mirror I/S R/V Tilt (Duplicate with D36)
D55  Console Front Compartment, Floor
D99  Body Provisions for Special Two Tone Paint
EN4  Cover, Rear Compartment Hard, Rear Compartment, Cargo
EVA  Test DVT, EVAP Emission Requirement
E37  Pickup Box, Inner DK Composite
E52  Body Equipment One Piece Lift Gate With Lift Glass
E95  Cover, Rear Compartment Tonneau, Rear Compartment
FF4  Arm, Left Torsion Bar Spring Adjustment ©
FF5  Arm, Right Torsion Bar Spring Adjustment (D)
FF6  Arm, Left Torsion Bar Spring Adjustment (E)
FF7  Arm, Right Torsion Bar Spring Adjustment (F)
FK2  Arm, Left Torsion Bar Spring Adjustment (A)
FK3  Arm, Right Torsion Bar Spring Adjustment (B)
FT2  Arm, Left Torsion Bar Spring Adjustment (FT2)
FT3  Arm, Right Torsion Bar Spring Adjustment (FT3)
F0F  Fleet Incentive Tourism Industry Inc. DBA Budget Sales and Leasing
F60  Spring Front Heavy Duty
GND  Sales Package Avalanche Ground Affects
GT4  Axle Rear 3.73 Ratio (DUP With 5 x 1)
GT5  Axle Rear 4.10 Ratio (DUP With GT8)
GU6  Axle Rear 3.42 Ratio
G63  Provisions, Luggage Carrier, Roof
G65  Level Control Manual, Self-Adjusting
G69  Level Control Auto, Air, HD
G80  Axle Positraction Limited Slip
G86  Axle, Limited Slip
JAN  Plant Code Janesville, WI, USA
JE1  Brake System, Europe
JF4  Power Adjustable Pedals
JH2  Brake Hyd Power, Disc/ Disc, 7,200 lb
JH6  Brake Hyd Power, 4-Wheel Disc, 9,900 lb
JL4  Control Active Brake
J81  Indicator Switch, Export
KA6  Rear Seat Heater
KC4  Heavy Duty Engine Oil Cooling
KG3  Generator 145 Amp
KNP  Cooling System Trans, HD
KUP  Throttle Control Electronic
K05  Heater Engine Block
K34  Cruise Control, Automatic, Electronic
K47  Air Cleaner High Capacity
K68  Generator 105 Amp
LM7  Engine Gas, 8 CYL, 5.3L, MFI, Iron, GM
LQ4  Engine Gas, 8 CYC, 6.0L, MFI, Iron, GM
LQ9  Engine Gas, 8 CYC, 6.0L, MFI, Iron, GM, HO
LR4  Engine Gas, 8 Cechy, 4.8L MFI, Iron, GM
L18  Engine Gas, 8 CYL, 8.1L, MFI
L59  Engine Flexible Fuel (Gas/Alc), 8 cyl, 5.3L, MFI, V8, GM
MN8  Transmission Auto 4-Speed, HMD, 4L80-E, Heavy Duty
MSL  Plant Code, Silao, Mexico
MTF  Provisions, Fire Extinguisher Mounting
MT1  Transmission 4-Speed Auto W/Elect Controls H.D. - Hydra-Matic 4L80-E
M30  Transmission Auto 4-Speed, HMD, 4L60-E, Electronic
M32  Transmission Auto 4-Speed Hydra-Matic Drive, 4L60-E Electronic, HD
NA1  Emission System GVW less than 8, 500 lb
NA4  Emission System GVW greater than 8, 500 lb
NC1  Emission System California, LEV
NF4  Emission System Clean Fuel Fleet
NF9  Emission System General Unleaded
NK5  Steering Wheel, Standard
NP5  Steering Wheel, Leather Wrapped
NP7  Steering Column, EEC Approved
NP8  New Venture Gear 246
NR3  Transfer Case - All Wheel Drive (AWD), Open Differential, Single Speed
NR4  Transfer Case - 4 Wheel Drive (4WD), Open Differential, 2 Speed
NT3  Emission System EEC 00
NT8  Emission System, Federal, Tier 2 A
NT9  Emission System Federal, Tier 2 Phase-out
NU4  Emission System, California LEV2 Plus
NW7  Traction Control - Electronic
NYS  Steering Four Wheel
NZZ  Skid Plate Off-Road
N12  Exhaust System Rear Exit
N30  Steering Wheel Deluxe
N88  Wheel - New - Aluminum - 17 x 7.5, Premium
N89  Wheel - New - Aluminum - 17 x 7.5, Sport
N93  Wheel - New - Aluminum - 17 x 7.5
N94  Wheel - New - Aluminum - 17 x 7.5, Chrome
PF4  Wheel - Cast - Aluminum- 16 X 7.0
PF9  Wheel - Cast - Aluminum- 16 X 7.0
PY0  Wheel - New - Aluminum - 16 X 6.5
PY2  Wheel 16 X 6.5 Chrome Appearance
P03  Wheel Cover, Var 3
P25  Wheel 17 X 7.5 Aluminum 5-Spoke Premium
P27  Wheel 17 X 7.5 Aluminum 6-Spoke Premium
P96  Equipment Mexican Modified, Mandatory Base Equipment
QAN  Tire All P265/70R 17 - 113S BW R/PE ST TL AL2
QAQ  Tire All P265/70R 17 - 113H BW R/PE ST TL AL2
QAS  Tire All P265/70R 17 - 113S WOL R/PE ST TL AL2
QB5  Wheel 16 x 6.5, Steel
QCP  Tire All P255/70R 16 - 109H BW R/PE ST TL ALS
QIW  Tire All LT245/75R16E R/PE ST TL OOR BL
QIX  Tire All LT265/75R16/C BW R/PE ST TL OOR 12OQ
QIZ  Tire All LT245/75R16/E BW R/PE ST TL OOR 12OQ
QJM  Tire All P265/70R17 - 113SWOL R/PE ST TL OOR
QJP  Tire All P265/70R17 - 113S BW R/PE ST TL OOR
QLP  Tire All LT2465/75R16/E BW R/PE ST TL ALS 120/116S
QMJ  Tire All P265/70R16 - 111S BW R/PE ST TL AL2
QMK  Tire All P265/70R16 - 111S WOL R/PE ST TL AL2
QNK  Tire All P245/75R16 - 109S BW R/PE ST TL ALS
QNL  Tire All P465/75R16 - 109S WOL R/PE ST TL ALS
RYJ  Shade Cargo Area, Retractable
R4W  Tire Brand All, Michelin
R4Y  Tire Brand All, Goodyear
R5C  Tire Brand All, Bridgestone
SAF  Lock, Spare Tire, Hoist Shaft
SLT  Equipment Chevrolet LT Sales Package
TL1  Grille Special
TRB  Grille Radiator, Body Color
TRW  Provisions Lamp, Roof Mounted
TR2  Lamp Turn Signal, Enlarged
TR3  Grille Radiator, Body Color w/Chrome Emblem
TR6  Headlamps Control Leveling System, Manual
T2H  Ornamentation Exterior, Export Unique Requirements
T2J  Ornamentation Interior, Export Unique Requirements
T62  Daytime Running Lamp System - Delete
T74  Headlamps Control Automatic, Delay
T78  Headlamps Control - Delete
T79  Rear Fog Lamp
T84  Headlamps, Right Hand Rule of the Road, E Mark
T89  Lamp, Tail and Stop, Export
T9H  Provisions Lamp, Front Fog
T96  Fog Lamps - Front
UB0  Radio AM/FM Stereo, Seek/Scan, CD, Auto Tone, Data System, Clock, ETR
UB1  Radio AM/FM Stereo, Seek/Scan, Auto Reverse Music, Search Cassette, CD, Auto Tone, Data System, Clock, ETR
UC2  Speedometer Instrument, Kilometers and Miles, Kilometer Odometer, Positive Bias
UC6  Radio AM/FM Stereo, Seek/Scan, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR
UD4  Alarm, Vehicle Speed, 120 K/H
UD7  Sensor Indicator Rear Parking Assist
UE1  Communication System Vehicle, G.P.S. 1
UG1  Garage Door Opened, Universal
UG2  Garage Door Opened, Universal - Delete
UJ6  Indicator, Low Tire Pressure
UK3  Control Steering Wheel, Accessory
UK6  Radio Control RR Seat And Earphone Jacks
UL2  Frequencies, European
UL4  Frequencies, South America
UL8  Frequencies, Saudi Arabian
UM7  Radio - AM/FM Stereo, Seek/Scan Clock, ETR
UM8  Radio - AM/FM Stereo, Seek/Scan CD, ETR, Navigation Clock
UQ3  Speaker System, Performance Enhanced Audio
UQ7  Speaker System Premium Performance, Enhanced Audio, Bose®
U01  Roof Marker Lamps
U1S  Player Multiple Compac Disc
U19  Speedometer INST, Kilo And Miles, Kilo Odometer
U2K  Digital Audio System S-Band
U34  Display Celsius Temperature
U42  Entertainment Package Rear Seat
U84  Antenna, Body Side Window, Radio
VBX  Language Label Arabic
VB3  Bumper Rear Step, Chrome, Impact Strip
VB5  Bumper Front, Color
VC4  Label Price/Fuel Economy, Puerto Rico and Virgin Islands
VC5  Label Shipping, Except US, US Possessions, or Japan
VC7  Label Price/Fuel Economy, Guam
VD1  Provision Options, Europe
VFF  Video Format Region 1, NTSC
VFJ  Video Format Region 2, PAL
VFK  Video Format Region 3, NTSC
VFM  Video Format Region 4, NTSC
VFP  Video Format Region 5, PAL
VGC  Protector Film, Paint Etch Preventive
VG3  Bumper Front Impact Strip
VG8  Vehicle Label, Notice to Buyer
VJ3  Label, Plate ECE Approval and Vehicle Identification
VK3  License Plate, Front Mounting Package
VPH  Vehicle Preparation - Overseas Delivery
VP6  Noise Control
VR4  Trailer Hitch Weight Distributing Platform
VR6  Hook, Tie-Down, Shipping
VR7  Hook, Tow, Second Rear
VT4  Bumper Front Color Keyed
VT5  Bumper Rear Color Keyed
VXS  Vehicle Complete
VZ2  Calibration Speedometer A
VZ3  Label, Mercury Disposal Notification
V1K  Luggage Carrier Bar, Center Cross
V20  Guard Radiator, Grille, Black
V22  Grille Radiator, Chrome
V3A  Guard Radiator, Grille, Gray and Chrome
V43  Rear Bumper Step, Color
V54  Roof Luggage Carrier, Painted
V73  Vehicle Statement, USA/Canada
V76  Front Towing Hook
V78  Vehicle Statement - Delete
V87  Vehicle Statement, Gulf States Organization
V92  Trailer Provisions
V98  Factory Delivery Processing
WBH  Merchandised Package, Base Decor
WV9  Merchandised Package, Value Leader
XAN  Tire Front P265/70R17-113S BW R/PE ST TL AL2
XAQ  Tire Front P265/70R17-113H BW R/PE ST TL AL2
XAS  Tire Front P265/70R17-113S WOL R/PE ST TL AL2
XCP  Tire Front P255/70R17-109H BW R/PE ST TL ALS
XGK  Tire Front LT245/75R16/E BW R/PE ST TL OOR 120Q
XHH  Tire Front LT245/75R16/E BW R/PE ST TL ALS 120Q
XHS  Tire Front P265/75R16-114H BW R/PE ST TL AT A Temp
XJM  Tire Front P265/70R17-113S WOL R/PE ST TL OOR
XJP  Tire Front P265/70R17-113S BW R/PE ST TL OOR
XLP  Tire Front LT245/75R16/E BW R/PE ST TL ALS 120/116S
XMJ  Tire Front P265/70R16-111S BW R/PE ST TL AL2
XMK  Tire Front P265/70R16-111S WOL R/PE ST TL AL2
XNK  Tire Front P245/75R16-109S BW R/PE ST TL ALS
XNL  Tire Front P245/75R16-109S WOL R/PE ST TL ALS
X88  Conversion Name Plate Chevrolet
YAN  Tire Rear P265/70R17-113S BW R/PE ST TL AL2
YAQ  Tire Rear P265/70R17-113H BW R/PE ST TL AL2
YAS  Tire Rear P265/70R17-113S WOL R/PE ST TL AL2
YCP  Tire Rear P255/70R16-109H BW R/PE ST TL ALS
YE9  Convenience Package Comfort and Decor Level #3
YGK  Tire Rear LT245/75R16/E BW R/PE ST TL OOR 120Q
YHH  Tire Rear LT245/75R16/E BW R/PE ST TL ALS 120Q
YHS  Tire Rear P265/75R16-114H BW R/PE ST TL AT A Temp Rating
YJM  Tire Rear P265/70R17-113S WOL R/PE ST TL OOR
YJP  Tire Rear P265/70R17-113S BW R/PE ST TL OOR
YLP  Tire Rear LT245/75R16/E BW R/PE ST TL ALS 120/116S
YMJ  Tire Rear P265/70R16-111S BW R/PE ST TL AL2
YMK  Tire Rear P265/70R16-111S WOL R/PE ST TL AL2
YNK  Tire Rear P245/75R16-109S BW R/PE ST TL ALS
YNL  Tire Rear P245/75R16-109S WOL R/PE ST TL ALS
Y91  Merchandised PKG Luxury Edition
Y92  Merchandised PKG Special Edition
ZCP  Tire Spare P255/70R16-109H BW R/PE ST TL ALS
ZGC  Tire Spare P265/75R16-114S BW R/PE ST TL AT
ZGK  Tire Spare LT245/75R16/E BW R/PE ST TL 00R 120Q
ZHH  Tire Spare LT245/75R16/E BW R/PE ST TL ALS 120Q
ZHS  Tire Spare P265/75R16-114H BW R/PE ST TL AT A Temp Rating
ZLP  Tire Spare LT245/75R16/E BW R/PE ST TL ALS 120/116S
ZMJ  Tire Spare P265/70R16-111S BW R/PE ST TL AL2
ZMK  Tire Spare P265/70R16-111S WOL R/PE ST TL AL2
ZM9  Sales Package Comfort & Convenience
ZNK  Tire Spare P245/75R16-109S BW R/PE ST TL ALS
ZNL  Tire Spare P245/75R16-109S WOL R/PE ST TL ALS
ZQ1  Chassis Package Smooth Ride
ZW7  Chassis Package Premium Smooth Ride
ZW9  Base Body or Chassis
ZY1  Color Combination, Solid
Z49  Export Canadian Modified, Mandatory Base Equipment
Z5X  Mirror Provisions, Arabic Language
Z55  Chassis Package Bi-State, Real Time Damping
Z66  Appearance Package Premium Ride Suspension
Z71  Chassis Package Off Road
Z75  Conversion Name Plate Cadillac
Z82  Trailer Provisions Special Equipment, H. D.
Z85  Chassis Package Increased Capacity
Z88  Conversion Name PLT GMC
Document ID# 1208230
2004 GMT 800
Source: Google Cache
Mine Says GQ1 GU6 G80
So i'm supposed to have a POSI. Hmmm... How is it supposed to behave? cause i've got stuck a couple of times and always got the Open Differential Symptom :chevy:
I opened it a year ago to see if everything was ok, and to change its oil. There is a kind of ratchet, and we figured it would engage in reverse.
Sounds like a locker right? (Posi locker.. locker.. :chevy::crazy: ) And it sure doesnt work :D
Pay me some fuel, and i'll do the ride with more pleasure than a man can possibly have driving his manual truck :D
Not sure how it works on older models since my LSD (Got the G80 as well, with 3.73 gears on a '05 Colorado Z71 2wd) is electronically controlled, but whenever I punch the throttle from a standstill or low speed, the RPMs drop and the wheels lock up. It's a mixed blessing as its helped me get out of some ditches before, and it has the unfortunate habit of engaging on dry pavement.
Got an auto trans and the I-5 engine (Vortec 3500, 5 cylinder 3.5L)
    Gilkey96
    Gilkey96
  • Who's Online   5 Members, 0 Anonymous, 863 Guests (See full list)
