Question about Underdrive puleys
Con's Reduced water pump speed bad in hot weather. Slower A/C speed= Less cooling inside. Slower Alt speed= lights dimming at night at idle. Can't see any Pro's with the Con's involved.
ASP makes the best for the trucks. To solve the Alt issue, you can get an overdrive pulley for that. But do keep in minf you are under driving the water pump too. I made a no BS 12HP with my ASP crank pulley alone. Took it off cause my truck started running hot.
  • 1 year later...
well the pros to any underdrive pully is less rotating mass.
Less rotating mass means the engine is moving less weight per cycle.
So you get more MPG and horsepower (more oculd even be .001 its still more).
You are not adding, so much as you are freeing up.
Some say they gain 10 horsepower (ls1's)
Some say they gain 8 (focus svt)
where I have seen alot of 4 cylinder domestics, not gain jack s**t from crank other than the negatives.
As for ls1's I have actually seen some decent gains (8 being the highest).
Cheers!
well that is good to hear. i dont have a huge stereo or big offroadlights or a winch so i dont see why this isnt the perfect upgrade to me.
thanks DayUSeX for the input. it seems around here everyone is 50/50 split about it. However is the overheating issues are for real then it makes me very very skeptical about it.
thanks again
My advice is to avoid ASP and anything that they make. I've had issues with them where they did not stand behind their products.
I've used a JET underdrive pulley on the 4.3 V6 and gotten really good results. Gained 2 mpg, which was a 10% increase. Thing is that was an older design of engine. I think that with a newer design engine you will not be able to improve as much.
Hey myfirstv8 can you tell me how the install went. I want to do this. What size belt did you need to get. Some people said there is ltos of cutting and griding, is this true??
And when looking at my stock underdrive pully i thought HOLY HELL. That thign is massive and must weigh a tone.
I wish that a company made lightend pullys for us 4.3 people =(
The install for the 4.3 was pretty easy. Just pull off the old pulley and bolt up the new one. I had to figure out the belt size myself since I did not use the alt pulley. A piece of string around the pulleys gives that #.
On the 4.8 I have no pulley experience. I'm betting that there is no pulley offered because the stock one is not a problem. I've got a 285 horse 4.8 and I still get over 19 mpg in my crew cab. The better the engineering that goes into a vehicle, the less room for improvement there is by the owner.
  • 1 month later...
This is an old thread, but I thought I'd give a little input here. The running hot issue could be solved by an electric water pump. That would be even better for power. Granted it would make this project a lot more expensive, but it's a very good option. As for the lights dimming, go with the above mentioned overdrive pulley for the alt. That should cover any problems. Power steering might be a little tougher, but that's probably not too bad.
  • 2 years later...
Well to resurrect this thread I am gonna shoot some questions here:
Has anyone installed a pulley set on the NNBS? I know its the same engine but clearance issues ect.
If installed have you seen the heating issue with the install...proven numbers?
If installed has someone seen problems with powering up HID's afterward?
Has anyone seen an electric water pump for the 2007 NNBS 4.8L?
Thanks
Justin
    needafix
    needafix
  • Who's Online   1 Member, 0 Anonymous, 557 Guests (See full list)
