2004 GMC Chrome Wheels
First, sorry if this is not the appropriate place to post things for sale.
I have a set of 4 wheels and tires that came off a 2004 GMC 2500 HD 4x4. They are the 16" x 6.5" 8-lug polished forged aluminum ones including the chrome center caps. The ones that are standard on the SLT and optional on the SLE.
They were on the truck for about the first 30 miles or so and I decided to put on some after market ones so the tires are still brand new.
They are just taking up space in my garage so they gotta go.
I will take the best reasonable offer.
Email me at [email protected] or call 360-933-1437 for details or purchase options.
I will take cash, check (must clear before being picked up or shipped), or credit cards (Through our business account although these are not being sold by our company).
Don't know what they are worth, but I would guess around $500 would be a good offer???
The wheels are located in Bellingham, WA, which is about 90 miles N of Seattle up I-5 or about 15 minutes S of the Canadian Border.
I can ship them anywhere in the US. I would estimate the shipping would be about $100.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
