Alignment specs
MR1911
I have a 2k Gmc serria 5.3 4x4 that needs another Alignment done and would like to know what the specs from gm are . I'm useing firestone and just paid for there lifetime Alignment and dont like the way they just did it , so I have to go back ,but would like to have the right numbers in hand to see if there specs are off or different.
:banghead:
This is going to come out terrible, maybe even unreadable, but it's in a table and they just don't cut/paste well into a plain text post. Hope you can make sense of this...
Wheel Alignment Specifications (4WD Pick-up)
Model
Caster degrees
Camber degrees
Sum Toe degrees
Z height (mm/in)
Steering Wheel Angle degrees
Important: Jounce the vehicle 3 times before checking the alignment in order to eliminate false geometry readings.
Important: The caster angle must be corrected to the level frame angle.
15 Series-Target Left Side
4.25
0.25
0.1
116 4.6
15 Series-Target Right Side
4.75
0.25
0.1
116 4.6
15 Series-Allowable Left Side
3.25-5.25
-0.25-0.75
-0.1-0.3
110-122 4.3-4.8
-5.0-5.0
15 Series-Allowable Right Side
3.75-5.75
-0.25-0.75
-0.1-0.3
110-122 4.3-4.8
-5.0-5.0
25 Series-Target Left Side
4.25
0.25
0.1
116 (4.6
25 Series-Target Right Side
4.75
0.25
0.1
116 (4.6
25 Series-Allowable Left Side
3.25-5.25
-0.25-0.75
-0.1-0.3
110-122 4.3-4.8
-5.0-5.0
25 Series-Allowable Right Side
3.75-5.75
-0.25-0.75
-0.1-0.3
110-122 4.3-4.8
-5.0-5.0
Down in the rear frame angles must be subtracted from a positive caster reading.
Up in the rear frame angles must be added to a positive caster reading.
Down in the rear frame angles must be added to a negative caster reading.
Up in the rear frame angles must be subtracted from a negative caster reading.
Model
Caster degrees
Camber degrees
Sum Toe degrees
Z height (mm/in)
4.25
0.25
0.1
116 4.6
4.75
0.25
0.1
116 4.6
3.25-5.25
-0.25-0.75
-0.1-0.3
110-122 4.3-4.8
-5.0-5.0
3.75-5.75
-0.25-0.75
-0.1-0.3
110-122 4.3-4.8
-5.0-5.0
4.25
0.25
0.1
116 (4.6
4.75
0.25
0.1
116 (4.6
3.25-5.25
-0.25-0.75
-0.1-0.3
110-122 4.3-4.8
-5.0-5.0
3.75-5.75
-0.25-0.75
-0.1-0.3
110-122 4.3-4.8
-5.0-5.0
:lol: That last part kinda throws me a bit ,it will will completely blow the techs mind I'm sure :shakehead:
Thank you so much this is what I need :mad:
As always you rock :P
