Yukon/Tahoe gas mileage question ???
Be kind too me as this is my first post :shakehead: . I bought a 2005 GMC Yukon with the 5.3 and a 4.10 rear SFI. The sitcker was 15/19 mpg. Junst wondering what have others experienced with gas mileage city vs. highway. I am getting 14 city and 18 highway. Does the mpg. increase as the SUV gets broken in? Trailering a 600# ATV and a 900# trailer, I'm getting 13.5 mpg. Thanks in advance for the posts.
Welcome, I wuld say you are par for the course. The MPG will increase a bit as the motor breaks in. Right now its tight (more friction). you should get a few more MPG.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
