Engine Block Heater
98silvz71
How does the engine block heater work? Is it possible to put on e on without to much difficulty? I park outside and I don't like to run the truck for too long in the mornings. Its about 10 degrees in the morning when I leave. Thanks in advance
It's a heating element that takes the place of a core (freeze) plug in the block. If you can find a core plug that's not too difficult to access, these are easier to install than putting in a new core plug.
Then you just plug it into an extension, make sure you don't forget and drive off while still plugged in and you're set.
I was thinking of buying a inline radiator heater. Would it be better than putting the element in a core plug? Its a 600W heater. Would that be good enough to actually be of use?
A block heater heats the coolant, that heats/warms the block along with the oil, which makes for easier starts. They suck up a lot of juice too. Easy to install yes, just put the B/H in the specific frost plug and point it the proper direction as told by the MFG.'s specs.
The thing is, you already have your vehicle started.
I think what you might be looking for is the in-line heater, supposedly they heat the heater core too and this is how you get your instant warm. My brother in-law had one years ago he thought it was great. Check into the in-lines more, I don't think that all of them will do this. (warmth)
I don't know much about the in-lines as I was/am more interested in the vehicle starting then getting into a warm truck.
BTW seeing as how winter is upon us and am still wondering what keeps me here I thought I might add, you ever get into a vehicle when its -40 celcius outside?(this is when celcius and farenheit are the same) Anyway the seat is a rock! Shutting the doors is like banging two pieces of metal together :flag: minus the twang and just trying to turn the ignition is very stiff. This is where the remote starters come in :fume: We don't get temps like this all that much maybe one or two nights a year.
:banghead:
John
edit: actually you can just by one of those car heaters that you put inside the vehicle and plug that in, assuming its heat you want.
