1993 S-10 Blazer 4WD for sale..FLORIDA
shorgasm
1993 4wd S-10 Blazer tahoe-trim Auto 4dr.Vortec V6 190hp code.Two-tone red. Power everything. Cloth.Nearly perfect inside.Good Stereo.Dark windows.VERY clean.It's got a bit of rust on the bottom of the front doors/mirrors and on the front fender corners.Typial Blazer spots.Florida truck.Underneath looks like new.Original exhaust switched out at 140k miles.That should give you an idea of the condition.It basically needs paint/body but still looks good from 10 foot or so.I think the tie-rods need attention as a does a pesky O2 sensor that makes it take longer to start than normal when warm..Cold it fires right up with a bump of the key.Could be a vacuum issue.I don't care because she does her job just fine adn really doesn't bother me..maybe 5 seconds or so.Gonna need tires soon and I think the brake booster might be on the way out.Passenger front window motor is about done.If the AC is on the pedal is up and fine.if the air is off it is low but still stops fine.I can tow my 4k lbs boat with it.I just bought a bigger truck for my next boat so I just drive this Blazer occasionally.If someone needs a good little truck with AC and 4wd.You really can't beat it.I'm in Daytona.
I'd like to get right around $2000 for it.
It's a dependable truck.Never left me anywhere.Its got its issues but in the end the AC is cold the push-button 4wd works perfect and it still runs strong.Does decent on gas.Its got 150k on her.No motor noises at all.No tranny problems whatsoever.Everything works right.
