04 S-10 Blazer
busta
Well we got our first substantial snow fall here in KS and wouldnt you know 4X4 on the wifes S-10 blazer wouldnt lock in...it is push button and the 4x4 high button lit up but never locked in...so wouldnt you know it when my wife needed it it wouldnt work...they have replaced the switch in it before so that is what my guess is...any other opinions...thanks for any help
2004 Chevy S-10 Blazer 4x4 4.3L
If the light comes on, and you hear the motor make the change, it's not the switch. There another part, actuated by vacuum, to enage the front diff, there may be a problem with that system.
Yep, you first need to determine if it's the front axle that's not engaging while the transfer case is, or if the transfer case is not even making the shift.
A 2004 sounds like it should still be under warranty unless you've put a lot of miles on it in that short time.
Turns out it was the sillinoid (sp?) on the front diff that locks it in...and yes it is under warranty so it got fixed yesterday and i picked it up last night...everything seems to work just fine
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 280 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
