Vibration on the steering
TwinTip
I had a 2000 Yukon and now have a 2003 Yukon, both 2WD. When driving I was/am able to feel every single bump or imperfection on the road through the steering wheel. This happens as I go slow or fast.
I have taken both trucks to the dealer and the problem was fixed under warranty. With the 2000 model, I only took it once before I sold it (had it for 3 years). The 2003 model has been at the dealer once already and I've started to feel the bumps again.
I remember that the dealer mentioned something about lubrication at some point in time. I wonder if this is something that I can fix myself or I need to take it back to the dealer? I'd rather do it myself if this is something that is easy to do. I'd hate to have to spend some hours waiting for the truck or arrange for pickup and drop-off.
I have many tools, grease guns, etc. Any suggestions? Is this something that I can do?
Thanks.
Is this the infamous intermediate steering shaft knock? Usually, those are only felt at parking lot speeds, not driving down the road, though I suppose it's possible.
Thanks GM. Is this something I can take care of, for example, lubricate, or is this something that only the dealer can correct? Is this a common problem (that is two out of two on the trucks that I've had)?
From your experience, how long should it take to correct this at the dealer?
Sorry for all the questions but with the Holidays coming up, does this need to be fixed immediately or can it wait without causing damage to the shaft?
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 501 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
