need a mechanic
gil_bo.. what truck are we talking about here, if your running a 4.3 V-6, you may be missing a few bolts out of pan. They tend to loosen up and fall out.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
