Another strange sound
When I hit a rough spot in the road I can hear a pretty loud sound coming from the left rear tire area. It only happens when the left tire or both tires hit the bump. The lug nuts are tight and the spare is also tight. It is a metallic clank that sounds like two pieces of something bouncing off of each other. I thought it might also be the e-brake cable but it is good and tight. It is 2wd with 75k on it. It seems to be nothing obvious, no scratches or worn spots anywhere in that area.
Thanks
When I rack my brain looking for an answer, I usually overlook the obvious. Sorry if you've hit these already...
Toolbox, hitch in reciever, fuel door, tailgate loose, Bump stop missing, bed bolts loose, truck cap door, last pedestrian you hit refusing to give up? :D
I think I've heard ppl with similar symptoms from something like a slip yoke driveshaft thing-a-ma-jig...?Don't really know much else, but I've got thousands of rattles on my truck (in bed and toolbox, not the truck itself!), so I'm probably not the guy to listen to! Sorry.
I bet the noise is your rear leaf springs clanging. There is an isolation "puck" that should prevent the noise from happening. Maybe yours is missing or damaged.
I had the same noise and it was the leaf spring "clapping" because of the isolation puck. The dealership replaced them twice before my warranty expired.
-Wardster
My truck did the same thing and it turned out to be the brake pads rattling. Sounds funny, but true. Try going over the same bump but with the brake applied, and see if it goes away. I had to replace my pads, and tension springs. Noise fixed
You guys are the heat! I'm going to check the leaf spring right now, since that pesky pedestrian finally gave up the ghost and let go. Can't wait to fix this, must stop hearing noise.
Chris
I owe you guys a beer!! I am missing the front and rear pucks on the bottom leaf on the drivers side. This will be fixed very soon. Sweeeeet, no more metal clanking over any bump!!!! This forum rocks! :cheers:
I hope the problem is fixed, and thanks for the compliment!!!
Everybody here at GM-Trucks deserves a thanks... All the members are great, and without them, we wouldn't have a site like this that all of us are proud to be part of!!!
    250.3k
    pimafe6931
    pimafe6931
  • Who's Online   2 Members, 0 Anonymous, 588 Guests (See full list)
    • Great info to have, I printed out what you had in your document as well as Newdudes post as I could see this mistake with the hardware happening very often if not realizing what type of special bolts are being used and just guess on bolt size for torque or the good enough "easy" method as per whack in the used bolts with an impact and send it !.
    • I installed the Auto stop eliminator on my 21 Sierra SLT shortly after I got it. They have a detailed video instruction on how, took me about 20-30 minutes to do. I was apprehensive too to start tearing apart a new truck but it was pretty easy install. Like you mentioned get some trim tools. I went to Harbor freight and picked up a set. If you can find some install videos/instructions to give you and idea for a plan of attack you should be fine.
    • If all oil manufacturers had to meet a higher standard for not just the initial filtering of the oil but that they had to improve on their formulation so that the oil cleaned the engine such as the Valvoline R&P or the new Mobil product ( assuming it works similar of course ), and the oil was changed on an interval based on good UOA data, there shouldn't be any gremlins running around like miniture rats on top of your heads to be washed down into the oil pan below 😁
    • Worst factory HD wheels GM makes
    • A while back on another thread there were comments and thoughts on air filters and I know that can tend to be a bit of a hot topic because of outfits that have a vested interest in selling aftermarket air boxes fitted with the gauze type of oiled elements touting the lower air restriction. However and unfortunately I don't know where I have seen the test results in the past about the amount of dirt through a test procedure that these style of filters do pass more dirt through than a properly designed ( not some cheap Chinese knock off ) paper/synesthetic media filter can do. Lake Speed had a conversation on that topic with one of the employees at Donaldson and there seemed to be a consensus of these oiled filters falling short in the absolute percentage of dirt holdback.    Which all ties back into how good the air filter is on the engine at keeping dirt out as that is going to reflect as a contaminant introduced into the oil as well as cylinder wear even if some of that dirt does find its way out of the exhaust rather then the crank case. Put another way that one can throw the kitchen sink at filtering the oil and using a bypass system which I fully expect will do nothing but good for the oils contamination but if the air filter system isn't doing its job then its preventing the engine from reaching the best wear/lasting case scenario instead.    Now perhaps this topic is or isn't for this particular thread but Grumpy Bear or anyone else for that matter, do you have access to some scientific trust worthy testing on engine air filter types to get some proper comparison data to post up.
